FS-III remklauw welke remschijven en blokken
Roeland80
Hallo,
Ik moet mijn remschijven en dus ook blokken vervangen heb achter 2 jaar geleden zelf gedaan dus moet voor ook lukken nu is mijn vraag welke schijven en blokken moet ik hebben?
Ik heb al gekeken op mijn sticker met PR codes alleen staan hier de achterremmen wel bij maar voor niet:
PRCode: 1AT = Electronic stabilization program (ESP)
PRCode: 1D0 = Without trailer hitch
PRCode: 1KD = Disc brakes rear
PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
PRCode: 1NL = Covers for alloy wheels
PRCode: 2UA = Standard design
PRCode: 3FA = Without roof insert (standard roof)
PRCode: 3GA = Without cargo area
PRCode: 3KD = Rear seat bench/backrest split folding
PRCode: 3L3 = Manual height adjustment for front seats
PRCode: 3QT = 3-point seat belts with tensioner and height adjustment front
PRCode: 3S2 = Black roof rails
PRCode: 4A0 = Without seat heater
PRCode: 4I2 = Radio remote controlled central locking operated from inside without safe lock
PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation
PRCode: 4X3 = Side air bag front with curtain air bag
PRCode: 5RQ = Right exterior mirror: convex
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 6FB = Body-colored exterior mirror housings
PRCode: 6Y0 = Without cruise control warning system
PRCode: 7A0 = Without CD changer/CD player
PRCode: 7AA = Electronic vehicle immobilization device
PRCode: 7MG = Emission standard EU5
PRCode: 7P4 = Manually adjustable lumbar support in front seats
PRCode: 7UC = Navigation system RNS315 (integrated data storage device)
PRCode: 7X1 = Park distance control
PRCode: 8AY = Radio/navigation system
PRCode: 8GU = Alternator 140 A
PRCode: 8L5 = Roof antenna and diversity window antenna
PRCode: 8QL = Key for locking system with remote control
PRCode: 8RM = 8 speakers (passive)
PRCode: 8WB = Front fog lights
PRCode: 8X0 = Without headlight washer system
PRCode: 9AK = Climatronic with impact pressure control free of cfc
PRCode: 9P1 = Seat belt reminder electric contact in buckle
PRCode: 9W5 = Car phone preparation
PRCode: B31 = Type approval the Netherlands
PRCode: E0A = No special edition
PRCode: F0A = No special purpose vehicle standard equipment
PRCode: G02 = Front shock absorption
PRCode: H0R = Tires 205/55 R16 91H optimized rolling resistance
PRCode: J2D = Battery 380 A (68 Ah)
PRCode: L07 = Suspension range 07 installation control only no requirement forecast
PRCode: QG1 = Service interval prolongation
PRCode: QN2 = Drawer under right front seat
ik had zelf deze gevonden en denk dat deze het ook moeten zijn:
Remschijf: https://www.autodoc.nl/ate/957397
Remblokken: https://www.autodoc.nl/ate/956202
De code staat in de klauw bij de voorremmen. Je zult gegarandeerd FSIII hebben
Die is 280mm rond en 22mm dik
Zo’n gecoate (naaf) schijf van ATE is perfect
En je geselecteerde blokken zijn de juiste
Roeland80
Top! Bestel ik deze!
Iemand nog een goedkooper adresje?
Roeland80
Van de week heb ik nieuwe remschijven en blokken geplaatst aan de voor kant. instalatie ging prima! Ik heb een paar youtube filmpjes bekeken en had al voor de achterkant een keer een terugstel tool gekocht voor de remzuiger... nu heb ik alleen bij lage snelheid dat mijn remmen piepen. Ik weet denk ik al waar het aan ligt maar nog geen tijd gehad om het spul los te halen.... ik ben volgens mij vergeten de achterkant van de remblokjes in te smeren met keramischvet heb ik toen ik de achterschijven en schijven vervangen heb wel gedaan. Maar hier zat een speciaal laagje op...
