crazybeeliuzhe
Hi Guys,
I have a 2004 fabia 1.2 htp azq. Recently the EPC light is on again and after scanning i found the following interesting things
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35 -10 Intermittent
16555 - Fuel Trim; Bank1 : System Too Lean
P0171 - 35 -10 Intermittent
These two error codes was found last winter and after i clear them, the don't come back. So i didn't pay attention. It seems this time the ECU decided to throw EPC light to alert me again, probably because the sensor's performance is getting worse.
Should I replace the Sensor 1?After searching around, Found that the sensor 1 is on top of the engine, so replacing by myself should be easy. Today i confirm the location of the sensor but i cannot find the plug of it. Does anyone of you can help me to point out the location of the sensor's plug?
You can find the picture of the engine as below:
https://onedrive.live.com/redir?resid=F0B1DDAC62C5DD53!11714&authkey=!AAivlK6Hcq_Av-k&v=3&ithint=photo%2cjpg
BTW, it's nice if you can recommend me a seller for the sensor. On ebay, there are some very cheap ones only for about 30 euro. are they trustable?
