MuiZ
Van het engelse skoda forum
misschien al eens gepost.... :crazy:
Remote Window Closure / Opening
When you lock/unlock the car, keep the button pressed on the fob and the window will raise/lower. take finger off button to stop
Windscreen Wiper Access
To get to the wiperblades, after having the ignition on, turn the ignition into the off position and pull down the wiper stalk. The wiper arms will move and stay in the full sweep position for you to clean/change the wipers. Putting the ignition back on and pushing the wiper switch down again sends the wipers back into their park position
Automatic Rear Screen Wipe
With the windscreen wipers on, selecting reverse will cause the rear screen wiper to wipe once.
Headlamp Washers (if fitted)
Headlamp washers only work with the lights on, and performs it's action the firstime you clean the windscreen and then every 5th time the windscreen is cleaned. Turning off the headlamps or ignition resets the counter.
Duel Zone Climattronic Synchronization
After a passenger has played around with their temperature settings, press the AUTO button for 3 seconds to re-sychronise
Coming Home Lights
The headlights only stay on for the 30seconds or so if you have put just taken the key out of the ignition. If you dont want them to stay on when youve parked up then lock the car, unlock and lock again.
(Save that oh too familiar "you've left your lights on mate!")
Duel zone climatronc switching between Celcius and Farenheit
Pressing and holding the Auto and Econ Buttons at the same time will swap the temperature from oC to oF and back again (can also be done on in trhe temperature settings if you have Maxidot.
maxidot
The MFD lights up when you open a door but will go out after about 30 seconds unless you do something. Just press briefly the trip button and the display will light back up.
Three blink indicator
IF you have maxi dot, this can be turned on and off in the options screen under ‘comfort coding’
Duel zone Climatronic settings
Like the previous version there are a ton of settings and information hidden in the climatronic computer.
To get this, press the ECON and the top right air direction button (next to recirc) simultaneously. To get back to temperature control press AUTO and ECON simultaneously
The passenger side temp control dial sets the section (1-30)
The fan speed dial sets the subsection and is shown in the passenger side LCD screen to the right of the main number.
The one that everyone wants is true speed, whis can be found in section 19.
Subsection 0 shows Kmh, subsection 1 shows Mph.
Subsection 3 shows the revs to the nearest 100 (tickover is about 870rpm and shows up as 08 on the display)
A little radio trick
If you hold down the MENU button whilst on FM or AM, until the radio emits a 'beep' the display will then alter to show a signal meter for the station you are listening to and some other useless stuff.
Auto shut off light
IF you forget to turn the lights off when you get out and lock the car, don't worry as the lights will turn themselves off after about 1 minute of the door being locked.
VIN numbers
Hold the info button on the radio and a list of VIN numbers come up.
Climate control recirc
When the car is put into reverse gear, the climnate control goes into recirculation mode to prevent fumes from getting into the cabin.
Low oil light
If you get a low oil level warning and then top up the oil but not by a sufficient amount, the low oil level warning light will go out anyway and stay off for 100 miles before coming on again.
Disabling of motion sensors for leaving window open
there are 2 ways
1) If you are by the car, there is a button in by the 'b' pillar on the drivers side, press that before locking
2) Press lock on the remote twice. This will also disables the deadlocks.
Coming Home Lights
maxidot
Auto shut off light
VIN numbers
Low oil light
there are 2 ways
