Ooit een keer naar gezocht aangezien een garage in de Meern na een lekke band met dit profiel verschil verhaal kwam.
"Gelukkig" hadden ze nog een gebruikte band liggen met een juiste profiel diepte voor een (voor hun) mooie prijs..
From Haldex: This is for Gen IV but their technical paper say the same for Gen I-III as well
Coupling Control Concept
Haldex Gen IV connects to the vehicle's electrical system and to the data communication bus (i.e. the CAN-system), transmitting information on the driver's actions, the engine, the transmission, the brakes and other on board systems.
Haldex Gen IV uses this information entirely for its control without the need for additional sensors. The available signals are received by the coupling's processor and interpreted by the software. Continuous analysis of these data adjusts the characteristics of the coupling according to actual demand, without any active intervention by the driver.
The function of the coupling is automatically adjusted to prevailing conditions. When starting in sand for example, the shafts are coupled together as firmly as possible to obtain the best traction. When close cornering, i.e. parking, the shafts are uncoupled to allow easy manoeuvring.
The controllability of the Haldex Gen IV also makes it possible to use differently worn tyres, to tow the vehicle with one axle raised, and to maintain function when using Run-flat-tyres or Mini-Spare.
Haldex Gen IV can use any suitable signal available on CAN. Signals from the ABS and ESP systems and the engine control are vital for performance. For enhanced performance, signals from a steering wheel sensor, yaw sensor, lateral acceleration sensor can be used if available.
Ik had de tekst nog, de link naar de source werkt helaas niet meer.
