In de handleiding van de nieuwe Octavia op skoda-auto.com, ik neem aan dat dit een accesoires is en dus niet standaard?
Daylight driving lights*
In some countries, the national legislation requires that the vehicles are equipped with the function daylight driving lights.
Switching on daylight driving lights
Switch on the ignition without turning the light switch out of the position 0.
Deactivate function daylight driving lights
Pull the turn signal light lever towards the steering wheel up to 3 seconds after switching on the ignition and at the same time, slide it to the bottom and hold it in this position for at least 3 seconds.
Activate function daylight driving lights
Pull the turn signal light lever towards the steering wheel up to 3 seconds after switching on the ignition and at the same time, slide it to the top and hold it in this position for at least 3 seconds.
When the daylight driving lights are switched on, the side lights and the low beam shine together.
On vehicles which are fitted with bulbs for daylight driving lights* in the fog lights, the parking lights do not switch on when activating the function daylight driving lights.
When the daylight driving lights are switched on, the illumination of the instrument cluster is switched off, however, it is switched on in the position
when it is dark and the low beam shines with full brightness (100 % of the performance).
On vehicles fitted with an information display*, you can activate or deactivate in the menu the function daylight driving lights:
SETUP (Settings)
Lights & Vision (Lights & Vision)
