Columbus Rear Seat Entertainment
barthoefs
Smartlink met RSE is volgens mij alleen de mogelijkheid om een SIM kaart te plaatsen, WLAN hotspot te gebruiken en de app SKODA MEDIA COMMAND te gebruiken. Voor de rest houdt dit volgens mij niks in.
https://play.google.com/store/apps/details?id=cz.skoda.mediacommand&hl=en
https://itunes.apple.com/us/app/skoda-media-command/id968010129?mt=8
This application from ŠKODA AUTO a.s. requires to have a car equiped with Rear Seat Entertainment functionality*.
Take control of your head unit directly from your tablet or your smartphone. Access the main functionnalities of your ŠKODA infotainment system and change your navigation target, manage your media, tune up your audio system and even more...
Highlighted features:
*Radio*
Control your radio station, tune it or save it to your favorite list from your smart device.
*Media*
Quick access to your personal music from external devices, internal memory or bluetooth streaming thanks to the ŠKODA Media Command App.
*Navigation*
Start your navigation from contact list, calendar or diary or use Google® Maps and Google® Search to find new destinations.
Check your current positon and how far away you are from your next destination. Remaining travelling time keep you informed no matter what.
*Sound*
Set up balance, fading and volume of your ŠKODA infotainment system and save your favorite configuration.
NOTICE: This application requires to be connected to your Škoda infotainment system over Wi-Fi.
To connect
STEP 1: From your head unit, go to "Settings" -> "WLAN" and for first time set up the connection
STEP 2: From your smartphone/tablet, go to settings and select the Wi-Fi network with same name as your infotainment system. If a password is required, you can find it in directly in the infotainment settings.
For more information, refer to the connection tutorial video included in the application.
*Application mode*
Go to the "Settings" -> "Mobile device data transfer" and choose one of the following modes:
- Deactivate: In this mode the application can only indicates current state of Škoda Infotainment system without possibility to control it.
- Confirm: Application can fully control your Škoda Infotainment system, but main requests like new destination shall be confirmed by the driver.
- Allow: All features are available without driver intervention.
*This Škoda app requires a vehicle-specific data interface. In order to display the app, the infotainment system must fulfil these technical requirements.
Please contact your Škoda Partner if you have any questions.
Ik heb in mijn o3 een usb aansluiting, daarop de accespoint, en daarop weer de hd.2 ipad gelijkertijd erop streamen, geen probleem en kids blij
Als ik het goed lees, verzorgt dan de access point de stroom voor de harde schijf (aansluitvolgorde is: USB-Stor.e Wireless-HD) Geeft de USB daar dus voldoende stroom voor? Zou een mooie oplossing zijn, ook voor mij.
Raiman
Ja dat klopt, gewoon de meest een eenvoudige casing nemen, usb gevoed natuurlijk. Zorgen dat de hd vol staat met mp4 films en via vlc op de ipads streamen
Wel aan de prijs. Met dat de oplossing van Toshiba en een 2Tb schijf van het zelfde merk ben je voor iets meer dan €100 klaar. Geeft wel iets meer zooi in de auto....
DoubleJ
Ik ben benieuwd of het überhaubt mogelijk is:
Video die op de Columbus staat afspelen op een extern scherm (bv. op de achterbank). Helemaal mooi zou zijn dat er op het externe scherm een film afspeelt en op het normale Columbus scherm de navigatie aanstaat. Is er iets van een Video output aan de achterkant van de Columbus?
Eventueel na vrijschakelen van VIM
