Cech
reactie op eerder posts
voor mij slimmer om ECU zaken uit te zoeken dan onder de kap duiken voor oxidatiepuntjes .... geen idee waar ik moet zoeken
"SKODA UITLEESRAPPORT"
Tuesday,17,March,2015,09:18:17:61453
VCDS -- Windows Based VAG/VAS Emulator
Mileage: 159720km-99245mi
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
Mileage: 159720km-99245miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 BK
Component: MARELLI 4LV G 3700
Coding: 00031
Shop #: WSC 13765
VCID: 5CBD9FC9CCDB8AC1527-4B4A
TMBCD46Y923295252 SKZ7Z0A0934365
3 Faults Found:
16785 - EGR System
P0401 - 35-00 - Insufficient Flow
17977 - Cruise Control Switch (E45)
P1569 - 35-10 - Implausible Signal - Intermittent
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V00
Coding: 00124
Shop #: WSC 13765
VCID: 3E7935413A87B8D15C3-515A
No fault code found.
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049
Component: BORDNETZ-SG. 1S30
Coding: 01170
Shop #: WSC 13765
VCID: 78F5E359582346E156F-513C
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 01
Coding: 12338
Shop #: WSC 13765
VCID: 2045EB39A033EE214EF-513C
Address 17: Instruments Labels: 6Yx-9xx-xxx-17.lbl
Part No: 6Y1 919 880 B
Component: KOMBIINSTRUMENT VDO V09
Coding: 16142
Shop #: WSC 11111
VCID: 458B5AAD5F51EB091D9-515A
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S30
Coding: 00014
Shop #: WSC 00820
VCID: 70E5DB7930531EA19EF-515A
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 G
Component: Lenkhilfe 0004
Coding: 00110
Shop #: WSC 00000
VCID: 336F147501C565B9A3D-515A
1 Fault Found:
01290 - Reference Voltage; Steering Assist
29-00 - Short to Ground
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 C
Component: 06 Komfortgerát 0003
Coding: 00067
Shop #: WSC 13765
VCID: 3B7F3C552995ADF97BD-4B00
Subsystem 1 - Part No: 6Q1959801
Component: 06 Tõrsteuer.FS TFK 0002
Subsystem 2 - Part No: 6Q1959802
Component: 06 Tõrsteuer.BF TFK 0002
End-------------------------(Elapsed Time: 03:05)--------------------------
verigens moet je niet alleen de accupolen en de accuklemmen checken, maar ook de verschillende stekkeraansluitingen. Bijvoorbeeld die van de ECU (ook een ECU die door bijvoorbeeld geoxideerde stekkeraansluiting te weinig spanning krijgt, kan rare dingen doen).
Overigens is 01290 de enige foutcode die tevoorschijn is gekomen, of had je er meer?
Coding: 00031
Shop #: WSC 13765
3 Faults Found:
16785 - EGR System
Coding: 00124
Shop #: WSC 13765
Coding: 01170
Shop #: WSC 13765
Coding: 12338
Shop #: WSC 13765
Coding: 16142
Shop #: WSC 11111
Coding: 00014
Shop #: WSC 00820
Coding: 00110
Shop #: WSC 00000
1 Fault Found:
Coding: 00067
Shop #: WSC 13765
