Meer info over mogelijke aanpassingen van TVS (vandaag op Facebook)
TVS Engineering
2 hrs ·
DQ380, DQ381 and DQ500MQB BOSCH software release
Dear All,
Finally after 8 months of testing we are happy to release our custom DSG software solutions for the DQ380, DQ381 and DQ500MQB Bosch gearboxes. All known packages are available, incl. stage 3 (up to 800Nm on stock clutch) and stage 4 (up to 1000Nm on a racing clutch).
The DSG software packages are identical to our DQ250 and DQ500 packages. For now, please refer to the DQ250 options list. Summarized, these options are available:
- Custom D shifting program
- Custom S shifting program
- Custom max RPM D+S+M
- Torque limiter raised
- Torque capacity increase
- Full manual mode M
- Kickdown disable in M
- Shifting Speed D+S+M upshift
- Shifting Speed D+S+M downshift
- Shifting paddles response
- Improved take-off
- Faster Launch Control take off
- Custom Launch Control RPM
- Custom multi-step Launch Control
- Reduced Launch Control brake release delay
- Engine breaking reduction
- MFA gear display indicator
- Launch control activation
- Improved Clutch cooling
- Improving Temperature monitoring
- etc.
Special racing features:
- Special racing take-off mode without torque reduction after normal take off
- Full racing mode files without torque reduction at all
These new gearboxes can be found in the following vehicles:
DQ380 = 0DE300XXX VW Golf 7.5 FWD 7-speed DSG (mainly China market)
DQ381 = 0GC300XXX VW Golf 7.5 AWD 7-speed DSG & Audi S3 2017+ AWD 7-speed
DQ500MQB Bosch is a bit more tricky, as the identification is almost the same as normal DQ500MQB gearboxes. DQ500MQB Bosch gearboxes can be found in the following vehicles:
Audi TTRS 8S 2017+
Audi RS3 8V 2017+
Skoda Kodiaq 2017+
VW Tiguan 2017+
Identification of both DQ500MQB & DQ500MQB Bosch look like 0DL300XXX. If unsure which gearbox is installed, just email us the ID and we will let you know.
In short future, all these gearboxes will also be used on new upcoming vehicles.
Normally, as for any DSG software request, it is sufficient to send us the OBD ID from the gearbox, the software request form in an email (with the VIN in the subject
However, if reading is required the procedure can be found below:
Reading procedure:
- Make sure you have TCM tool version 0103 or newer
- Connect the TCM tool directly to the gearbox using the normal DQ500 adapter cable
- Identify the gearbox to make sure all connections are ok
- Power off ECU
- Power on ECU and press READ without identification first (this must be done within 5 seconds after powering up the ECU)
Please find attached the updated pricelist.
If you have further questions, feel free to contact us.
For pricing related questions please contact Rick at
rick@tvsengineering.nl
For technical related questions please contact Dirk at
dirk@tvsengineering.nl
Kind regards,
Rick Schouten
TVS Engineering/DSG Dokter
Valutaweg 12
7051 EA Varsseveld
The Netherlands
M +31 (0) 653 750 427
NEW
http://www.instagram.com/tvs.engineering
www.tvsengineering.nl
www.facebook.com/tvsengineering
