hobbel de bobbel
UPDATE
I dropped the car off today and was called back 4 hours later to say it was they had been able to perform the test this time with advice from head office and the the system appeared to be working correctly. I asked how the system had been tested and was told that the official test procedure involved the use of a small amount of LPG to trip the sensor. I was also told that they had performed the same test on a new vehicle to confirm that it switched to recirculation in the same way. I have no knowledge of the test procedure they used so I don't know if it is able to test the sensitivity of the sensor or whether it only tests for functionality.
The customer service rep had no explanation for why the system doesn't go to recirculation when driving behind badly smoking exhausts (burnt oil and petrol smell) so given they diagnosed a different fault first time round and then concluded on the second visit that it was working correctly I have concluded that they were not familiar with the system and the test procedure.
Is the air quality sensor only useful if I drive through a gas leak!
