Staat er niets in de Ross-Tech wiki?
Gateway The Gateway (aka. Diagnostic Interface for Databus OR CAN-Gateway) is responsible for passing Messages from one Control Module to another, older versions of the Gateways were not compatible and wouldn't allow a Diagnostic Tool like VCDS to communicate with the new Radio Navigation System.
Address 19: CAN Gateway Labels: 1K0-907-530.lblPart No SW: 1K0 907 530 Q HW: 1K0 907 951 Component: J533__Gateway H16 0202 In this Example the Software Part Number is 1K0-907-530-Q, only Gateways with this Part Number (or newer) are known to be compatible with the RNS310. For the VW Passat (3C) only Gateways with the Part Number 3C0-907-530-E (or newer) are known to be compatible.
Installation & Wiring
Additional Information can be found in the Repair Manuals, the Wiring Diagrams, the Parts Catalog and/or the Instructions included in the Retrofitting Kit.
Configuration
The following Activations are necessary to ensure that the newly fitted parts are properly recognized and are ready to use.
- Update the Installation List in the Gateway (J533 / #19).
- Register the newly added 37 - Navigation Control Module, in case you had a Navigation System installed before the Retrofit this step may not be necessary. Address 56 - Radio should also be activated in case there was no Radio installed prior to the Retrofit. Even though Address 56 - Radio is registered, the RNS310 will NOT communicate via that Address - you have to use 37 - Navigation instead.
Volgens mij (van wat ik zo gelezen heb op de diverse fora) is de oplossing van die leeglopende accu toch echt een nieuwe gateway...
Denk het ook. Alleen die zijn best prijzig (voor wat het inweze is).
Heb ik ook al voorgehad... Bij de garage hadden zo ook geen oplossing. Wél zagen ze dat ik een firmware update kon gebruiken... Als je naar het maximum volume ging kon je als je stil stond hééééééél erg zachtjes wat muziek horen.Mijn Admunsen + wel degelijk vastgelopen voor de eerste keer! Gisteren stapte ik terug in de wagen , met draaiende motor, en net op dit moment dat de bluetooth de gsm oppikte, had ik blijkbaar een gemist gesprek.Door dit voorval was de klank volledig uitgevallen (zowel radio,navi,media..). Het contact afleggen en terug starten gaf geen oplossing.
Pas toen ik op bestemming na een 20tal minuten terug in de wagen plaats nam, werkte alles terug naar behoren.
Is er nog iemand die dit al voor had, en hoe kan men dit dan vermijden?
Hallo forumleden,
Sinds kort heb ik in mijn Fabia Combi 1.4 (2009) de radio, model Dance, vervangen door een Amundsen+ (RNS315). Nu schakelt de Amundsen na een half uur vanzelf uit. Daarnaast reageert het systeem niet op het aan- en uitschakelen van het contact. Ik moet de radio dus handmatig aan- en uitzetten. Hoe is dit probleem op te lossen? Moet de radio via de vag-com aangemeld worden (en zo ja, hoe moet dat, welke codering?)?
Groet,
Jeroen
